03-26-2019 06:01 AM
Hi All
All my SCCP phones clocks seem to have changed time to 1 hour back 1 week early.
The SIP phones all seem to be OK.
We are running CUCM v11.5
How should I resolve this ?
I cannot afford to wait a week without changing it to the correct time
Many thanks
03-26-2019 06:48 AM
Check there the NTP Server source from, check NTP Settings sync status.
If CUCM is NTP Soruce post from CUCM
#utils ntp status
03-26-2019 08:43 AM
We are not using NTP
03-26-2019 09:23 AM
how is your CUCM/ Phone clock source from ?
03-27-2019 04:10 AM
It was manually set.
I tried creating a device pool and date/time group with NTP, it did not fix the issue.
I have logged a case with our third party, they said a DST fix is needed.
03-26-2019 06:59 AM
Have you checked if the ntp is correct on your CUCM?
utils ntp status
George
