allow-connections sip to h323 command not supported
HusseinLTD
I have 4331 router running SDWAN 17.x image.
trying to configure voice but it's not supporting the following 2 comands:
allow-connections h323 to sip
Call flow: PSTN >> FXO on router >> CUCM
while I have FXO with analog lines, is there anyway I can make this work?
16 Replies 16
Von,
The licensing scheme is different when the router is running Controller-managed mode. By default, all feature sets are enabled as soon as you move from Autonomous to SDWAN.
It's better to check if the commands are supported on SDWAN, rather than licensing. Some voice features were not available in early 17.X versions, but 17.9/17.10.
HusseinLTD
Hi everyone, you guys are right, I thought h323 is required, but that's wrong.
and the issue I was facing is because the configuration is missing the "bind" commands, when I push the configuration on vManage to the router it doesn't show me any errors, but when I SSH the router I don't see the "bind" commands, TAC says it's a bug in vManage
