AnalogLine from SP
johntim20
Dear Experts,
1) I would like to Add '0' to an 10 digit incoming call because i am getting only 9 digits from the SP on AnalogLine terminated on FXO using H323 Protocol with CUCM 8.5 this line is dedicated to the manager for both incoming and outgoing, i have configured ' !' as the route pattern for making any types of outgoing calls. and also created 1 voip dailpeer pointed to cucm and 1 pots dialpeer for outgoing.
2) I would like to strip 3 digits from the inoming call because the SP is sending the area code as well in the same region number  that is (030-44536254), i want to strip 030 and get only 7 digit call.
Any Translations rules or do i need to add prefix on the gateway or translation pattern.could any one provide with the best solution.
Thanks in Advance,
paolo bevilacqua
There are very many threads about these exact matters, have you tried searching before asking?
