Dear Experts,
1) I would like to Add '0' to an 10 digit incoming call because i am getting only 9 digits from the SP on AnalogLine terminated on FXO using H323 Protocol with CUCM 8.5 this line is dedicated to the manager for both incoming and outgoing, i have configured ' !' as the route pattern for making any types of outgoing calls. and also created 1 voip dailpeer pointed to cucm and 1 pots dialpeer for outgoing.
2) I would like to strip 3 digits from the inoming call because the SP is sending the area code as well in the same region number that is (030-44536254), i want to strip 030 and get only 7 digit call.
Any Translations rules or do i need to add prefix on the gateway or translation pattern.could any one provide with the best solution.
Thanks in Advance,
