Android software for DX70 & DX80 still?
hankej
We purchased a DX 70 and 80 off of Ebay and I got them configured and registered with CUCM 12.5.1.
The DX 80 is registered as Cisco Webex DX80 and running load version: ce-9.12.1-8a845789ad6-2020-03-20
The DX70 is registered as a Cisco Telepresence DX70 and is running load version: ce-9.14.2-a4fd41aa839-2020-08-31
This is my first time using these, but I understand that you used to be able to use Android code on them.  Is this still possible?  I don't have Smartnet on the devices as Smartnet cost a lot more than it did to purchase them.  Just wondering if it is even possible to put the Android code on them.
Jaime Valencia
You should be able to do so if you get all the necessary code to downgrade it, however, the last Android load is almost 4 years old, and it reached EOL 2 years ago, you'd be running 4 year old firmware with no updates/patches whatsoever.
java
if this helps, please rate
Better to Use CE software than using outdated android version.  if I am not wrong latest android firmware available on portal has  android 4.
Response Signature
