answer address prior to incoming called-number: is it possible?
I want to know whether there is any way to make dial-peer with certain answer-address  to match prior to dial-peep with incoming called-number .T ?
Seems like I found another way to solve my issue.
cadet alain
You can give the least preferred dial-peer a preference > 0 and change global config dial-peer hunting to choose preference first.
Regards.
Alain.
Have tried it already  - didn't work for me. Two simple dial-peers, need 2nd to be matched if 5555 is calling:
dial-peer voice 1 voip
preference 10
dial-peer voice 2 voip
answer-address ^5555$
Selected 3rd option
R1(config)#dial-peer hunt ?
  <0-7>  Dial-peer hunting choices, listed in hunting order within each choice:
  0 - Longest match in phone number, explicit preference, random selection.
  1 - Longest match in phone number, explicit preference, least recent use.
  2 - Explicit preference, longest match in phone number, random selection.
  3 - Explicit preference, longest match in phone number, least recent use.
  4 - Least recent use, longest match in phone number, explicit preference.
  5 - Least recent use, explicit preference, longest match in phone number.
  6 - Random selection.
  7 - Least recent use.
dial-peer hunt 2 didn't work?
Regards.
Alain.
