03-04-2011 03:40 AM - edited 03-16-2019 03:47 AM
I want to know whether there is any way to make dial-peer with certain answer-address to match prior to dial-peep with incoming called-number .T ?
03-04-2011 06:48 AM
Seems like I found another way to solve my issue.
03-04-2011 06:52 AM
You can give the least preferred dial-peer a preference > 0 and change global config dial-peer hunting to choose preference first.
Regards.
Alain.
03-04-2011 07:29 AM
Have tried it already - didn't work for me. Two simple dial-peers, need 2nd to be matched if 5555 is calling:
dial-peer voice 1 voip
preference 10
dial-peer voice 2 voip
answer-address ^5555$
03-04-2011 11:44 AM
dial-peer hunt 2 didn't work?
Regards.
Alain.
