Answer Delay problem on FXO ports
kelimeyers
I have 2811 series router with FXO ports. We use 7940 and 7960 phones. Gateway is setup in Call Manager as H323. When calls come in, it takes 3 PSTN rings before the router answers the call (as seen by ccapi debugs). The only config I have on the voice-ports is "connection plar opx", otherwise default settings are used. Can anyone tell me how to get the router to answer the call more quickly? Thank you!
PATRICK ALAND
The FXO ports are waiting for Caller-ID information to be delivered by the telco. You can disabled this under the voice-port, i.e.
voice-port 0/0/0
no caller-id enable
If you need Caller-ID you can try reducing the number of rings by:
voice-port 0/0/0
ring number 1
PATRICK ALAND
voice-port 0/0/0
no caller-id enable
voice-port 0/0/0
ring number 1
Thank you very much! That worked wonderfully!
