Answer Emergency Call
chris.warren
Is anyone aware of a way to drop an active call in order to receive an emergency call?
Anas Abueideh
Level 9
Level 9
what do you mean by emergency ? how did you classify the call to be an emergency call
Anas
Jaime Valencia
Assuming you have CUCM, use MLPP
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
