Answering Calls Issue
jefferymitchell
I have a department that consists of 16 operators that answers the same DN. Today the department started experiencing an issue with answering incoming calls. When an incoming call would come in the call will appear on all phones. When an operator tried to answer the call it would continue to ring as if it was not answered. This problem happens sporadically and is not isolated to the same phone, this issue is occurring on different phones. Anyone have an answer or has experienced this issue before?
Nadeem Ahmed
What is the call-flow , are these incoming call coming over FXO or PRI?
Br, Nadeem Please rate all useful post.
These calls are incoming from PSTN over PRI. We have 5X24 channels. I don't see any errors on our Voice Gateway all they way back to our Switch that these phones connect to. It is isolated only to the phones with this particular DN. We have other phones at this location that are not experiencing this issue. There are approximately 16 phones that are configured with this DN. I have set Max Calls to 20 busy to 18. I've rebooted each phone. I can't isolate what the cause is. It just began this afternoon. There was no changes made on CUCM to these phones.
is that calls hit the Hunt-group first on CUCM and then to users? Did you tried deleting and re-creating it again HG
Also if issue still persisting do you minding share CUCM traces for this scenario . and also collect the GW logs too
if your GW is MGCP then
debug mgcp packets
debug isdn q931
if your GW is H.323 then
debug h225 asn1
debug isdn q931
debug h245 asn1
debug voice ccapi inout
if your GW is SIP then
debug ccsip message
debug isdn q931
I have attached the real time data report for calls to this extension. I'm seeing "(41)Temporary Failure" As the cause of termination.
