Showing results forĀ
Search instead forĀ
Did you mean:Ā
Any performance issues with 400 + users on a CUCMBE?
andyhibbert
I currently have a CUCMBE 7.1.3 system with 150 users. This seems to run ok with out any performance issues.
I'm looking to add around 300 more users to this system.
Can the CUCMBE actually support this number of users in the real world ?
(It's a different question as to whether or not it's sensible to have this number of users on a single server solution.)
Andy
Jaime Valencia
CUCMBE is supported with up to 500 users.
Cisco Unified Communications Manager Business Edition
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/vcallcon/ps7273/product_data_sheet0900aecd805e6985.html
Table 1. System Capacity
Attribute
Capacity
Maximum number of users
500
Maximum number of mailboxes and voicemail ports
500 mailboxes and 24 voicemail ports
Number of remote sites
20 (centralized call processing, with Cisco Unified Survivable Remote Site Telephony [SRST])
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
Attribute
Capacity
500
java
java
Thanks for the info.
Is there anyone out there  actually running 400+ users on a CUCMBE ?
