Any translation rule gurus
e.huntley
The documentation is baffling to me and is probably right before my eyes, but here is what I want to do.
In normal mode with MGCP gateways, we are taking 10 digits inbound on our PRI. In CCM, I am taking the last 4 digits and prepending a 4. So 1234 turns into 41234 as a DN
I want to be able to do the same thing in SRST mode. So I need a translation rule that says take the last 4 and add a 4.
So for example even if wrong
/..../ /4..../ Whatever the proper wilcards are.
Thanks to all
Brandon Buffin
Assuming that inbound calls are to number in the block 1112223XXX, the following translation rule will translate anything beginning with 1112223 to a number beginning with 43. The remaining digits will be carried through.
voice translation-rule 1
rule 1 /^1112223/ /43/
voice translation-profile 1
translate called 1
dial-peer voice 1 pots
incoming called-n .
direct-inward-dial
translation-profile incoming 1
Hope this helps. If so, please rate the post.
Brandon
PETER NEGUS
a slightly nicer way is
voice translation-rule 4
rule 1 /.*\(....\)$/ /4\1/
voice translation-profile STRIP-DNIS
translate called 1
dial-peer voice 9 pots
translation-profile in STRIP-DNIS
incoming called-number .
Or try [assuming your DID is 666555xxxx]
call-manager-fallback
dialplan-pattern 666555.... extension-length 5
extension-pattern 4....
Which does it all in one command, but litters the system with hidden dial-peers.
