Anyone have sql command for returning external phone mask with DN & Description of Phone
sandreone_2
Hi there,
Does anyone have full sql which will return the DN, External Phone Mask, and Description of Phone?  I get close with the sql command below, but still cannot get the description to appear.
admin:run sql select dnorpattern, e164mask, tkpatternusage from devicenumplanmap  inner join numplan on fknumplan=numplan.pkid where e164mask= "1234567890"
Thanks in advance,
Sharon
You were 80% there:
run sql select dnorpattern, d.description, e164mask, tkpatternusage from devicenumplanmap  inner join numplan on fknumplan=numplan.pkid  join device d on fkdevice = d.pkid
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
testeven
Hi Sharon,
I believe you need to add a union command, something like this:
admin: run sql select dnorpattern from numplan union select description from device
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
You were 80% there:
Aaron Harrison
Aaron,
Thanks so much for your feedback.  It worked great.  Here's the sql command used since I was looking for a particular number.
run sql select dnorpattern, d.description, e164mask, tkpatternusage from devicenumplanmap  inner join numplan on fknumplan=numplan.pkid  join device d on fkdevice = d.pkid where e164mask= "1234567890" "NUMBER"
This saved me several hours in Call Mgr.
Thanks again,
Sharon
