07-12-2016 11:44 PM - edited 03-17-2019 07:31 AM
Dear Guy
I'm a new in cisco phone.
Is there any way to set up the password on CP 7821?
it is not activated on CUCM(Device > Device Settings > Common Phone Profile).
Please let me know how to resolve it.
07-12-2016 11:57 PM
Hi Baek,
You will need to apply it on the Common phone profile only, there is no other option apart from using extension mobility
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7811-7821-7841-7861/10-1/english/adminguide/PA2D_BK_7479E876_00_7811-7821-7841-7861-ag-cucm-1031/PA2D_BK_7479E876_00_7811-7821-7841-7861-ag-cucm-1031_chapter_011.html#CUIP_TK_AEA44E63_00
You can apply a password to the phone so that no changes can be made to the administrative options on the phone without password entry on the Administrator Settings phone screen.
07-13-2016 12:04 AM
07-13-2016 12:15 AM
No extra license is needed for this feature. If you have access to cucm admin page then follow steps 1-3 of my earlier email. Go to Device > Device Settings > Common Phone Profile > Click on Add New
Create a new profile , give it a name and a password in the Local Phone Unlock Password field. Then go to the 7821 phone and select this profile from the Common Phone Profile dropdown field on the 7821 phone config page and reset the phone.
Manish
07-13-2016 12:53 AM
oh i tested it. but it's my misunderstanding.
Actually my question is is it possible to apply password the phone on calling out?
07-13-2016 01:03 AM
Yes, please read this doc to configure FAC and configure accordingly, its explained in detail with screenshots
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/81541-fac-config-ex.html
Manish
07-13-2016 09:56 AM
http://docwiki.cisco.com/wiki/Endpoints_FAQ#Can_I_lock_my_phone.2C_or_require_a_PIN_before_making_calls.3F.3F
