Arabic Language Pack for the IP Phones
tiger_401
Dear All,
I am running call manager 9.1.
All my ip phones are by default using english language.
Some of my users need to use arabic language on the ip phones.
i have 7911, 7941, 7965, 7970, 9971 ip phones in my network .
Kindly gudie me the procedure to perform this task.
Malik.
3 Accepted Solutions
Aman Soi
Hi Malik,
U can refer the links
for downloading Arabic Locale
http://software.cisco.com/download/release.html?mdfid=284510097&flowid=37562&softwareid=282074333&release=9.1(1.1000-1)&relind=AVAILABLE&rellifecycle=&reltype=latest
for uploading locale on CUCM server: u need to do on all servers in all cluster and also restart the server.
http://docwiki.cisco.com/wiki/Cucm-phone-locale-installers#CUCM_User_Locale_and_Network_Locale_support
Try doing it on one phone.
regds,
aman
Hi Malik,
Try to change user locale on one of the ip phone by logging through call manager.
regds,
aman
Hi Malik,
Sorry for late replies.It is the same file as confirmed by you  is working for other phones as well.
regds,
aman
20 Replies 20
Aman Soi
Hi Malik,
regds,
aman
Hi Aman,
Thanks for the response.
Can i use this file as well po-locale-ar_SA-9.3.3.1000-1.cop.sgn
Malik
Hi Malik,
You need to install cm-locale-ar_AE-9.1.1.1000-1.cop.sgn.
POLI are required only when phone firmware upgrade are changed w/o doing CUCM upgrade.
regds,
aman
Hi Aman,
Actually we did migration from mcs with cucm 6.1 to ucs with cucm 9.1 through DRS.
So in this case which file i have to use file starting with cm or po
Malik
Hi Malik,
You go ahead with CM file .
regds,
aman
Ok Aman,
I have uploaded the files suggested by you on both the nodes pub and sub and followed the steps mentioned in the second link provided by you
Please find the screen shot
kindly let me know how i can change the language on the ip phone
Malik
Hi Malik,
regds,
aman
Hi Aman,
Please find attached the screen shoot.
I have restarted the tftp do i need to restart the whole server as well ?
Malik
its working fine now
so now i need to do the same steps for the other phone types
i tested with 7911
thanks a lot Aman
Malik.
Hi Malik,
Did u restart the CUCM server or it worked by restarting tftp server ?
Try with other model as well.
regds,
aman
Hi Aman,
It worked without restarting the cucm server i just restarted the tftp and it worked fine
i am now installing the lang pack for other phone types and will update you
Thanks  a lot
Malik
Hi ,
Since it is a new locale, so, please restart the server.
regds,
aman
Hi Aman,
For other fone types for example 7942, 7965 or 9971.
The same cop file which i used for 7911 will work for i need to download different file for different phone types
Malik
Hi Aman that same file which you posted worked for all the phone types
Malik
