Are UC applications supported on Kernel-based Virtual Machine(from Red Hat)?
Nirmal Joshi
Level 4
Level 4
I am working on a IP Telephony POC.
My client is asking me to get all the UC applicatons working on KVM (Kernel-based Virtual Machine) from Red Hat.
I do not if this is every tested by Cisco, has anyone done this before?
Is there a document which lists supported server virtualizaton hypervisors from different EOMs with Cisco UC applications?
One thing I am going to ensure that the recommended/below mwntioned hardware specs are adhered to for this POC.
Server UsageVM OVA CapacityVM   OVA ParametersNotes
vCPU CoresPhysical   CPU Load was Calibrated TovRAMvDiskvNIC
(= Physical Cores)(=Physical   Memory)(=Physical   space)
PublisherUnified   CM 2500 users
     (with 800 MHz reservation)
2.53   GHz
4   GB
     (with 4 GB reservation)
1x   80 GB disk with pre-aligned disk partitions
12.5K   phones per VM
SubscriberUnified   CM 2500 users
2.53   GHz
4   GB
12.5K   phones per VM
Cisco Unified   Presence Server2000   Full UC Users1   vCPU (1500 MHz reserved)4   GB
1x   80 GB vHDD1
Header 1Header 2
2.53   GHz
4   GB
12.5K   phones per VM
2.53   GHz
4   GB
12.5K   phones per VM
1x   80 GB vHDD1
Will this POC work with Red Hat KVM or I will have to use ESXi for server virtualization?
Please suggest.
2 Accepted Solutions
Chris Deren
Have you reviewed these pages in detail:
http://docwiki.cisco.com/wiki/Unified_Communications_in_a_Virtualized_Environment
Cisco has very stringent guidelines on how UC on UCS/VMware needs to be configured.  I suggest you review this in detail.
HTH,
Chris
Yes, that's true for any of the supported HW, TRC, TRC spec based or 3rd party spec based.
Roadmap questions cannot be addressed here, you need to submit those to your SE/AM
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
8 Replies 8
Chris Deren
HTH,
Chris
Chris,
Thanks for looking into this.
Here is what I see from the link which you provided.
Supported Virtualization Hypervisor Vendors
At this time, the only vendor supported for UC is VMware.
Other vendors/products - such as Microsoft Hyper-V, Citrix Xen, Red Hat KVM - are not supported for Cisco UC virtualization.
So I beleive this is also true for third party specs based servers as well.
Is there any roadmap for other virtualization vendors/products for UC?
Nirmal
java
java
Thanks Java
Other vendor servers are supporter as Spec Based, see this page for details:
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware
HTH,
Chris
Thanks Chris
tom golan
Hi Guys, Are there any plans to support KVM in the near future?
As I already mentioned in the previous replies, forward looking questions are considered NDA material and cannot be discussed here. You would need to direct your question to your SE/AM.
That is in regards to UC apps that run on UCS and are listed here:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/cisco-collaboration-virtualization.html
The only exception to that rule is CUE, which can run on KVM on IOS, and is not listed in the above doc.
java
