AS5400
kendon3733
Hey all,
I have not programmed voice in years and I am programming an AS5400 as PRI.
I setup the primary D channel just fine but when I try to do the backup D channel
it gives me this error:
CCT_ATT_SE_VOICE#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
CCT_ATT_SE_VOICE(config)#controller T1 7/0:1
CCT_ATT_SE_VOICE(config-controller)#pri
CCT_ATT_SE_VOICE(config-controller)#pri-group t
CCT_ATT_SE_VOICE(config-controller)#pri-group timeslots 1-24 nf
CCT_ATT_SE_VOICE(config-controller)#pri-group timeslots 1-24 nfas_d p
CCT_ATT_SE_VOICE(config-controller)#pri-group timeslots 1-24 nfas_d primary n
CCT_ATT_SE_VOICE(config-controller)#pri-group timeslots 1-24 nfas_d primary nfas_int 00 n
CCT_ATT_SE_VOICE(config-controller)#pri-group timeslots 1-24 nfas_d primary nfas_int 00 nfas_group 1
CCT_ATT_SE_VOICE(config-controller)#controller T1 7/0:2
CCT_ATT_SE_VOICE(config-controller)#prig
CCT_ATT_SE_VOICE(config-controller)#pri-group timeslots 1-24 nfas_d b
CCT_ATT_SE_VOICE(config-controller)#pri-group timeslots 1-24 nfas_d backup n
CCT_ATT_SE_VOICE(config-controller)#pri-group timeslots 1-24 nfas_d backup nfas_int 01 n
CCT_ATT_SE_VOICE(config-controller)#pri-group timeslots 1-24 nfas_d backup nfas_int 01 nfas_group 1
%The Primary-group is already defined
%The first definition of the primary-group must be removed
before the primary-group can be redefined
I must be missing something. Any ideas.
Thanks.
9 Replies 9
clileikis
Level 7
Level 7
Hi Kendon,
Looking at your config you've configured the backup d channel on the same controller (T1 7/0) , typically you'd see the backup d channel configured on a seperate T1 controller which is why I think you're seeing that error message.
Also, here's a doc that may help:  http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a00800a6bf2.shtml
HTH,
Chris
I will take a look at the document. This is a channelized DS3 so I should have 28 T1's so I don't get why I can't have a primary and a backup unless I need to program the DS3 different.
I am not sure why - but I removed the T1's after shutting down the T3 controller and then readded the T1's and now I am able to add the primary and backup Pri's.
controller T1 7/0:1
shutdown
framing esf
pri-group timeslots 1-24 nfas_d primary nfas_int 0 nfas_group 1
controller T1 7/0:2
shutdown
framing esf
pri-group timeslots 1-24 nfas_d backup nfas_int 1 nfas_group 1
controller T1 7/0:3
framing esf
pri-group timeslots 1-24 nfas_d none nfas_int 2 nfas_group 1
Very weird, I may have not done it in the correct order or something.
Thanks for the help.
One last question when I look at my T3 controller it says the line code is B3ZS and I need it to be B8ZS. Do you know how I change this, it is not under the controller itself.
Hi Kendon,
You're probably in the controller t3 interface, you'll need to move to the individual t1 controllers to configure the B8ZS linecoding, ex.  controllter T1 7/0:1
Chris
That is what I though as well but there is no line code under the individual controllers:
CCT_ATT_SE_VOICE(config-controller)#?
Controller configuration commands:
  cas-custom     cas group customization configuration
  channel-group  Specify the timeslots to channel-group mapping for an interface
  default        Set a command to its defaults
  description    Controller specific description
  ds0            ds0 commands
  ds0-group      Replacement of cas-group. Configure group of timeslots to a particular signaling type
  exit           Exit from controller configuration mode
  extsig         Configure an external signalling protocol - { mgcp }
  fdl            Specify the FDL standard for a DS1 data link
  framing        Specify the type of Framing on a DS1 link
  guard-timer    Guard timer (0-20) for xcsp calls - timer duration and accept/reject on expiry
  help           Description of the interactive help system
  loopback       Put the entire T1 line into loopback
  no             Negate a command or set its defaults
  pri-group      Configure the specified timeslots for PRI
  shutdown       Shut down a DS1 link (send Blue Alarm)
  snmp           Modify SNMP controller parameters
  trunk-group    Configure interface to be in a trunk group
  voice-class    specify a voice class
Also, do you know where to change the bearer capability on the AS5400?
The test calls are failing due to the bearer capability being set to data.
I found and fixed the bearer capability but now I get a modem tone when I make a test call.
I was missing the voice-port 7/0:1:D on the pots dial-peer.
I have the test call working now.
thanks,
