Assign Line or Soft Key from expansion for door opening
info
Hello everybody.
I have connected to my CUCM (sip version) an 2N Helios IP Doorphone, and is working just fine.
To open the door relay switch, i press 00 during the call answer.
Is there a way to assign a key (soft key or line key) to a phone (ex.cisco 8851) so when answering the door phone , just only to press the shortcut key to open the door?
I've thought of it like sending a DTMF command 00 while on call...
Can this be done and how?
Thank you
HARIS_HUSSAIN
I think it is not possible.
Only thing possible it to configure speed dial and use command to give a pause to connect call and dial the DTMF after the pause as per below configuration.
https://supportforums.cisco.com/document/126846/pause-speed-dial-cucm-9x.
Haris
