CUBE sent request cancel
ahmed
i have CUBE sip trunk to PBX (lnternal side) and sip trunk to SBC (provider), i have configure CUBE, and outgoing call from PBX succeed.
but incoming from provider failed, i look into pbx and found (use wireshark) the cube has sent invite to pbx, called number from provider translated into extention 100, BUT after sent invite, CUBE also sent request cancel, then call failed.
cube is 172.16.20.249 and pbx is 172.16.20.252
please advise
regards,
ahmed
Ayodeji Okanlawon
From the logs
++ Cube sent INVITE for extension 100 to PBX++
Sent:
INVITE sip:100@172.16.20.252:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.20.249:5060;branch=z9hG4bK5022EA
However PBX sends the call back to the CUBE
Apr 11 16:58:33.423: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:100@172.16.20.249:5060;user=phone SIP/2.0
From: 081211199919<sip:081211199919@172.16.20.252:5060;user=phone>;tag=6b1-42c56310-fc1410ac-13c4-32920-38ffe4cb-23b
To: <sip:100@172.16.20.249:5060;user=phone>
Call-ID: 6ae-42c86970-fc1410ac-13c4-32920-6ba6b2eb-23a@172.16.20.252
CSeq: 1 INVITE
Via: SIP/2.0/UDP 172.16.20.252:5060;branch=z9hG4bK-32920-c58a505-5d8f83c1
The call then goes into a loop.
Please check your PBX configuration. Why is the PBX sending calls for this extension back to the CUBE gateway?
Please rate all useful posts
