Associate PSTN number with DN number
Hi All, I am unable to bind my one phone line with IP phone extension number. Please advise.
I have 2 PSTN Lines, 1 (37776666) which is connected FXO port 0/0/0 and 2 (38885555) which is connected FXO port 0/0/1.
I have 4 IP Phones .(1)  ext # 111, (2) ext # 222, (3) ext # 333 and (4) ext # 444.
I want to bind 37776666 number with ext # 111. i want to restrict all extension numbers to user this line 37776666 except ext # 111 as it's CEO ext #.
Below is my configuration.
voice-port 0/0/0
 connection plar opx 111
 description out 37776666 via 111 CEO
 caller-id enable
voice-port 0/0/1
 connection plar opx 222
 description out 38885555 via 222 Reception
 caller-id enable
dial-peer voice 110 pots
 destination-pattern 9T
 port 0/0/0
dial-peer voice 120 pots
 port 0/0/1
ephone-dn  1
 number 111
 label A
 description Line 1 04236400719 CEO
 name A
ephone-dn  2
 number 222
 label B
 description Line 2 04237564464 Reception
 name B
ephone  1
 device-security-mode none
 mac-address 001A.A1CF.2233
 button  1:1
ephone  2
 mac-address 0017.956C.A00F
 button  1:2
7 Replies 7
osamaokok
I have the same issue! any help?
BR
DaviRocK!
try translate your pstn inbound line with extension plar
example
num-exp 37776666 111
num-exp 38885555 222
Hi, May you please share the exact commands. i will be thankfull to you.
BR,
Misbah Ul Haq
Hi Dmarazza,
BR,
Misbah Ul Haq
DaviRocK!
Did you tried with
in conf terminal
Hi Dmarazza,
It's not working.
0092 country code
42 city code and
3777666 and 3888555 are phone numbers
I tried with and without country code.
num-exp 04236400719 111
num-exp 04235764464 222
With country code
num-exp 00924236400719 111
num-exp 00924235764464 222
Please advise.
BR,
Misbah Ul Haq
Hi All,
I have two Issues.
1. Directories Issue
I have two Cisco 7941 IP Phnes. both are registered with 2811 CME and working good.
one 7941 IP Phone showing me all numbers like mobile numbers, extension numbers, land line numbers in Directorries > Missed calls, Received calls and Placed calls but the second 7941 IP Phone is not showing me mobile numbers, land line numbers in Directories > Missed calls, Received calls and Placed calls. this 7941 IP phone only showing me extension numbers in Directories > Missed calls, Received calls and Placed calls.
2. Redial Issue.
all numbers which are displaying in Directories > Missed calls or Received call unable to dial when i select the number and click on dial. the number display on screen without 9 and not process.
normaly when i dial any number i press 9 before dial the number. but i am unable to dial Missed calls and Placed calls.
Please advise.
BR,
Misbah Ul Haq
