ATA 186 - How to disable pre-call services
uldericonucci
I'm not able to contact extension *XXX (ex. *123) using an analog phone connected to ATA 186 with SCCP firmware.
The digit "*" is considered special because is used to activate pre-call services (ex. **1 to call forward all).
It's possible to disable pre-call services, or to choose another digit instead of the "*" ?
Migrate the ATA to H323 could be a workaround?
Many thanks,
Ulderico
hadbou
Level 5
Level 5
A subsribed service enable/disabled by the user can
# be disabled/enabled dynamically on a per call basis;
# Possible values:
# bit 0 (mask 0x1): FORWARD_ALL -- forward unconditional
# bit 1 (mask 0x2): FORWARD_BUSY --forward on busy
# bit 2 (mask 0x4): FORWARD_NOANS -- forward on no answer
# bit 3 (mask 0x8): CLIP_CLIR -- CLIP
# bit 4 (mask 0x10): CALL_WAITING -- call waiting
# bit 5 (mask 0x20): 3WAY_CALLING -- 3-way calling
# bit 6 (mask 0x40): XFER_BLIND -- blind transfer
# bit 7 (mask 0x80): XFER_CONSULT -- consult transfer
# bit 8 (mask 0x100): CALLERID -- caller ID
# bit 9 (mask 0x200): Call Return
# bit 10 (mask 0x400): MWI -- message waiting indication
# bit 15 (mask 0x8000):FAXMODE -- FAX mode
This URL should also help you:
http://www.cisco.com/univercd/cc/td/doc/product/voice/ata/ataadmn/atasip/sipagch3.htm#xtocid0
hadbou
Level 5
Level 5
# Possible values:
Excellent!! Thank you very much!
