02-02-2020 09:16 AM
I am sure this device is doomed for the recycle bin, but first I would like to see if there is anything that I may be missing. The device powers on, green light stays lit (no blinking if connected to the network). Red light lights once, and does nothing if pressed. No IVR is heard at any time. Does not appear on the network. Worked fine prior.
Solved! Go to Solution.
02-07-2020 10:32 AM
Assuming that you have enabled already the cdp command in the switch, maybe its time to “recycle” your ATA.
George
02-02-2020 11:50 AM
Have you tried to check if the ATA is shown attached on your switch, by using the command "show cdp neighbors detail"?
G
02-07-2020 08:18 AM
There is no info returned when issuing the "show cdp neighbors detail". I am using a lab cisco switch. There is nothing else on it. The interface light on the switch is not lit as well.
02-07-2020 10:32 AM
George
