ATA 187 configuration on CME version 10.0
ngigi0001
HI,
I have been trying to get my Cisco ATA 187 to register to CME  Ver 10.0 to no success.
Am using http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#10910
Kindly assist.
Mukuu
ngigi0001
Below is my Config,
Kindly let me know what am missing.
Current configuration : 18061 bytes
! Last configuration change at 21:01:50 UTC Mon Mar 30 2015
version 15.4
hostname VOIP_CME
boot-start-marker
boot system flash:c2951-universalk9-mz.SPA.154-3.M2.bin
boot-end-marker
card type e1 0 2
card type e1 0 3
enable password Cisco
no aaa new-model
clock timezone UTC 3 0
network-clock-participate wic 2
network-clock-participate wic 3
ip cef
no ipv6 cef
isdn switch-type primary-net5
cts logging verbose
voice-card 0
voice service voip
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
voice register global
 mode srst
 max-dn 500
 max-pool 250
 authenticate realm string
voice register pool  11
 id mac 0008.3031.39D9
voice translation-rule 1
 rule 1 /^.*730144\(000\)/ /100/
 rule 2 /^.*730144\([1-9]..\)/ /\1/
voice translation-rule 2
 rule 1 /100/ /0730144000/
 rule 2 /\([1-9]..\)/ /0730144\1/
voice translation-rule 4
 rule 1 /9/ //
voice translation-rule 10
 rule 1 /^.*4944\(000\)/ /100/
 rule 2 /^.*4944\([1-9]..\)/ /\1/
voice translation-rule 20
 rule 1 /100/ /0204944000/
 rule 2 /\([1-9]..\)/ /0204944\1/
voice translation-rule 30
 rule 1 /100/ /204944000/
 rule 2 /\([1-9]..\)/ /204944\1/
voice translation-rule 111
 rule 1 /^.*\(1-9..\)/ /\1/
 rule 2 /000/ /100/
voice translation-rule 222
 rule 1 /100/ /0709824000/
 rule 2 /\([1-9]..\)/ /0709824\1/
voice translation-profile 111
voice translation-profile AIRTEL_IN
 translate called 1
voice translation-profile AIRTEL_OUT
 translate calling 2
voice translation-profile INCOMING_TKL
 translate called 10
voice translation-profile OUTGOING_TKLISDN
 translate calling 30
voice translation-profile SAFCOM_IN
 translate called 111
voice translation-profile SAFCOM_OUT
 translate calling 222
voice translation-profile TKLOUTGOING
 translate calling 20
voice translation-profile TKL_INCOMING
 translate called 10
voice translation-profile TKL_INT_OUTGOING
license udi pid CISCO2951/K9 sn FHK1439F2HW
license accept end user agreement
license boot module c2951 technology-package securityk9
license boot module c2951 technology-package uck9
license boot module c2951 technology-package datak9
hw-module pvdm 0/0
hw-module pvdm 0/1
username admin privilege 15 password 0 Cisco
username Cisco privilege 15 password 0 Cisco
redundancy
controller E1 0/2/0
 pri-group timeslots 1-31
controller E1 0/2/1
 framing NO-CRC4
 pri-group timeslots 1-26
controller E1 0/3/0
 framing NO-CRC4
controller E1 0/3/1
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.1
 encapsulation dot1Q 1 native
interface GigabitEthernet0/0.2
 encapsulation dot1Q 2
 ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/1
 ip address 192.168.10.5 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/2/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
interface Serial0/2/1:15
 no ip address
 encapsulation hdlc
 no cdp enable
interface Serial0/3/0:15
 no ip address
 encapsulation hdlc
 no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/0
 cptone KE
 timeouts call-disconnect 2
 timeouts wait-release 2
 timing hookflash-out 500
 connection plar opx 100
 caller-id enable
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/2/0:15
voice-port 0/3/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/1:15
voice-port 50/0/28
 station-id number 139
voice-port 50/0/28
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer cor custom
 name Internal
 name ALL
dial-peer cor list PT-ALL
 member ALL
dial-peer cor list PT-Internal
 member Internal
dial-peer cor list CSS-ALL
 member Internal
 member ALL
dial-peer cor list CSS-Internal
 member Internal
dial-peer voice 1 pots
 corlist outgoing PT-ALL
 translation-profile incoming AIRTEL_IN
 translation-profile outgoing AIRTEL_OUT
 destination-pattern 9T
 incoming called-number 0730144...
 direct-inward-dial
 port 0/2/0:15
dial-peer voice 2 pots
 translation-profile incoming TKL_INCOMING
 translation-profile outgoing TKLOUTGOING
 destination-pattern 8T
 incoming called-number 0204944...
 direct-inward-dial
 port 0/2/1:15
dial-peer voice 3 pots
 translation-profile incoming SAFCOM_IN
 translation-profile outgoing SAFCOM_OUT
 destination-pattern 6T
 incoming called-number 0709824...
 direct-inward-dial
 port 0/3/0:15
gatekeeper
 shutdown
telephony-service
 max-ephones 165
 max-dn 500
 ip source-address 192.168.2.1 port 2000
 auto assign 63 to 63
 system message MEDIAMAX_DSM
 max-conferences 4 gain -6
 web admin system name admin password Cisco
 dn-webedit
 time-webedit
 transfer-system full-consult
 create cnf-files version-stamp 7960 May 28 2014 11:13:36
