12-16-2014 01:18 AM - edited 03-17-2019 01:20 AM
I got cisco ATA 187 (for fax) and try to configure it on CME 9.0 but it not registred on CME.
ATA platform : APP187.9-2-3-1
voice register global
mode cme
source-address 10.14.20.254 port 2000
max-dn 80
max-pool 80
tftp-path flash:
file text
voice register dn 1
number 4099
name FAX
label FAX
voice register pool 1
id mac 0C85.25A6.9798
type ATA-187
number 1 dn 1
codec g711ulaw
12-16-2014 06:23 AM
Is your registrar expiration set? Try using the below. This is a common oversight with CME and SIP.
registrar server expires max 1200 min 300
Also, make sure you are re-creating your profile just in case something got messed up.
03-03-2015 04:42 AM
Have you checked the ATA187 got correct IP and TFTP server?
Go to web site (http://ATA187's IP) and check a status.
It will give you all current IP assignment, call manager and status of registration.
Check this below link.
Also, make sure you have correct configuration file, ATA[MAC-address].cnf.xml
for the sample configuration file.
Check this link as well.
Good luck
03-03-2015 05:48 AM
Try adding username and password under voice register pool 1
username ATA187 password test
Also, please post the following debugs "debug tftp events" and "debug ccsip messages"
FG
