ATA 187 with fax, cannot do outside calls
JohnPeca18
Can you help us with ATA187 fax issue?  Outgoing calls does not work. Ingoing calls work.
I have seen this document
https://supportforums.cisco.com/docs/DOC-25210
But I didnt find our call flow situation. Our call flow is
Telco - PRI - GW - H323 - CUCM - SIP - ATA187- Fax
What is the right configuration with this scenario?
Any help is appreciated.
CUCM Version
9.1.1.20000-5
GW image
flash0:c2900-universalk9-mz.SPA.150-1.M1.bin
ATA187 fax mode is set to NSE passthrough G711alaw
If you need any more information let me know
thanks
John
JohnPeca18
We solved this by commands
voice service voip
modem passthrough nse codec g711alaw
on GW
