04-16-2018 01:25 AM - edited 03-17-2019 12:37 PM
We recently procured 3 units of CISCO ATA 190 to connect our analog conference devices into CUCM 11.0.1.
We have deployed around 120 CISCO SPA 514G for our end users.
I could not able to configure the ATA 190 manually via Web browser since all values on the each menu are not editable.
I already created new phone on CUCM but still not able to connect.
04-16-2018 05:46 AM
Does the ATA obtain proper TFTP option from the DHCP server?
Have you run through the checks outlined here:
05-04-2018 01:02 AM
Following are logs of TFTP and VLAN
Mar 9 16:46:44 ATA190 daemon.debug vsock: [cucm_init: 218]cucm tftp init done Mar 9 16:46:44 ATA190 daemon.debug vsock: [cucm_load_tftp_addr_dhcp: 554]to parse dhcp result in file: /tmp/vlan/extopt_br0.conf Mar 9 16:46:44 ATA190 daemon.debug vsock: [cucm_load_tftp_addr_dhcp: 579]tftp option: tftpsvr 10.x.x.x 10.x.x.x Mar 9 16:46:44 ATA190 daemon.debug vsock: [cucm_load_tftp_addr_dhcp: 620]buf == 10.x.x.x, domain_name=domain.org, tftp_cnt=0 Mar 9 16:46:44 ATA190 daemon.debug vsock: [ctftp_entry_add_dn: 91]adding TFTP domain: 10.x.x.x Mar 9 16:46:44 ATA190 daemon.debug vsock: [cucm_load_tftp_addr_dhcp: 620]buf == 10.x.x.x, domain_name=domain.org, tftp_cnt=1 Mar 9 16:46:44 ATA190 daemon.debug vsock: [ctftp_entry_add_dn: 91]adding TFTP domain: 10.x.x.x Mar 9 16:46:44 ATA190 daemon.debug vsock: [cucm_load_tftp_addr_dhcp: 554]to parse dhcp result in file: /tmp/vlan/extopt_br0.conf Mar 9 16:46:44 ATA190 daemon.debug vsock: [cucm_load_tftp_addr: 695]loaded 2 tftp server Mar 9 16:46:44 ATA190 daemon.debug vsock: [cucm_load_info: 287]loaded tftp address Mar 9 14:18:57 ATA190 daemon.debug sprvoip: SCAPC_init(): provision_enable=0 prule=/spa$PSN.cfg tftp=
===============================Connected to Voice VLAN======================================
Mar 9 16:45:47 ATA190 daemon.debug sprvoip: voice vlan = 200
Mar 9 16:45:50 ATA190 daemon.info system[1]: vlan-module send out delete interface(br0, 0x8) notify...(0)
Mar 9 16:45:50 ATA190 daemon.info system[1]: vlan-module send out update interface(br0, 0xa) notify...(0)
Mar 9 16:45:50 ATA190 daemon.info system[1]: vlan-module send out add interface(br0, 0x8) notify...(0)
Mar 9 16:45:50 ATA190 daemon.err system[1]: start 0 vlan-id... ok
Mar 9 16:45:51 ATA190 auth.err vlan_udhcpc: syslog: unknown facility/priority: 1149c
Mar 9 16:45:51 ATA190 local3.warning vlan_udhcpc: adapter hardware address dc:xx:94:1d:xx:xx
Mar 9 16:45:51 ATA190 local3.warning vlan_udhcpc: wan_mac ========== DC:xx:94:1D:xx:xx
Mar 9 16:46:44 ATA190 daemon.debug vsock: [cucm_load_domain_name: 813]to parse dhcp result in file: /tmp/vlan/extopt_br0.conf
Access the device via IVR requires 16 digit of activation code, we have no activation code. do I need the activation code?
also it using essential license provided by CUCM.
08-14-2019 01:41 AM - edited 08-14-2019 01:42 AM
I have the following configuration - three Call Managers in a standalone cluster - one publisher and two subscribers. CM System version: 12.5.1.11900-146. Latest ATA 190 firmware - cmterm-ata190.1-2-2-003_SR1-1.
For ATA 190 to successfully register in CUCM check and do:
Installed latest firmware 1.2.2(003_SR1-1) in the CallManager(CM) or CM cluster;
TFTP service Started and Activated on all CallManagers;
DHCP server up and running to serve the network;
Then follow the workarounds from CSCun74479:
ATA190 DHCP Option 150 TFTP server IP address not used
CSCun74479
Description
Symptom:
ATA190 will not use the TFTP server IP address provided by the DHCP server via the option 150 parameter.
ATA will not know which TFTP server to query in order to download its configuration and eventually register to CUCM
Conditions:
ATA 190 with 1.1.0(004) firmware or earlier
Workaround:
There are two workarounds,
1. Define option 15, domain name, on the DHCP server.
2. Configure TFTP server address manually via IVR or webGUI
For IVR, hit ****
Enter password, default is 24726
Enter option 221 to configure TFTP server IP address
Enter option 110 to Show IP address of the ATA
For webGUI, go to the webpage {IP address taken from option 110}
Login as admin,
username admin
password admin
Go to Voice >> Provisioning
TFTP Server: {enter IP or name of the Publisher}
CUCM Domain Name: {Your Domain Name}
Provide line 1 and line 2 with DN and the ATA190 registers successfully in CM and is ready for phone calls.
Hope this help.
