ATA 190
joseramontorres
Hello there, i bought a ATA 190, 2 Port Analog Telephone Adapter Voip Gateway Phone but ir arrived without the ATA-PWRCLIP-NA (ATA power clip for North America) very little clip, does this mean i will not be hable to connect the product to the power outlet whe i want to install it?
Best Regards
Gregory Brunn
You will need to purchase one as this device is not PoE.
https://www.cisco.com/c/en/us/products/collateral/unified-communications/ata190-2-port-adapter/datasheet-c78-731473.html?cachemode=refresh
See comments on this
The Cisco ATA190 is sold with a power adapter and clip. Only one power adapter is offered which is compliant worldwide, however, power clips differ by region and must be selected as an option at the time of ordering. Mileage may vary if ordering from websites that are not Cisco partners.
Gregory Brunn
Thanks very much for your response, best regards
