ATA 192
cghaderpour
We have a few offices that we need to have ATA and printer connected to the same switch port on Meraki MS. The port is configured in access mode and allows traffic for VLAN x (data) and VLAN y (Voice). we have the ATA connected to switch port and using the LAN port on the ATA we connect the printer. (ATA must act as a switch to provide network access for printer like an IP phone). Printer has static IP on data VLAN and ATA gets a dynamic IP from DHCP on voice VLAN. the ATA is set to bridge mode.
with this setup printer communication is totally lost and ATA does not pass the traffic for data vlan over the built-in switch on the device. If I remove the voice vlan config on the MS port and only have Data VLAN in the config, then both devices are on the same VLAN and the traffic can pass through the ATA built-in switch and they both are happy. The problem is that ATA does not pass the traffic with Data vlan tag if the ATA itself is on voice VLAN.
Any idea what must be done on ATA or anywhere else to make this work properly and separate the traffic for printer and ATA on their own VLANs?
Leo Laohoo
Is there a CUCM in the network?
If there is no CUCM, make sure to get the ATA 192 with MPP/3PCC firmware.
As far as I am aware, there is no way to convert an ATA 192 from Enterprise firmware to MPP/3PCC (and vice versa).  So make sure to buy the right "mode".
Another option is to get an ATA from a different manufacturer.
