ATA192 - SYSLOG events
ManyATA192s
Hi - We use multiple ATA192's per site and would like to use SYSLOG to capture onhook and offhook events - due to there being no unique device identifier in the SYSLOG frame this makes it impossible to identify the source of the message (the individual ATA) in the application layer - would it be possible to add the sender MAC in the message please?
ManyATA192s
Hi - A further update - we solved the MAC address issue by renaming the 'Hostname' field - but due to the ATA192 insisting on logging to a file once this file reaches capacity the events are no longer logged until cleared via the web page - also the inability to disable events created due to SSL Error when accessing ATA-192 web pages means the logs are filled mostly with these events - another device we use (Grandstream HT-802) allows logs to file or server or both - is there any reason Cisco can't do this?
