Auto menus on called systems not responsive sometimes
Michael Durham
Level 4
Level 4
When I call a business such as Verizon, they have an auto-attendent where I must make a selection usint the touchpad.  When IO make a selection, many times it does not register with them  The problem seems worse when you need to enter several digits such as a PIN or credit card number.
I am running CME 8.6 and using Cisco 7940/60 phones.  Any suggestions as to how to fix this?  Do I need to increase DTMF tone time?
Michael
Chris Deren
What firmware file are you using on the phones?
What DTMF method is used on the incoming dial-peer (post config if you are unsure).
Chris
dial-peer voice 911 voip
corlist outgoing Door-EMS-Only
destination-pattern [2-9]11
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 100 voip
description *** Incoming Calls VoIP ***
translation-profile incoming Incoming_calls
incoming called-number 9045551212
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 210 voip
corlist outgoing Door-National
description *** Outbound 11 Digit Dialing Calls ***
destination-pattern 1[2-9]..[2-9]......$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 200 voip
description *** Outbound 10 Digit Dialing Calls ***
translation-profile outgoing Ten_Digit_Dialing
destination-pattern [2-9].........$
dtmf-relay rtp-nte
codec g711ulaw
no vad
telephony-service
max-ephones 20
max-dn 20
ip source-address 172.16.1.1 port 2000
url services http://singlewire.com/freeservices/menu
load 7960-7940 P00308000500
time-zone 12
voicemail 2000
max-conferences 4 gain -6
transfer-system full-consult
directory entry 1 1001 name Michael Durham
create cnf-files version-stamp 7960 Nov 09 2012 14:46:17
It this all you need?
Change one of you dial-peers to have:
incoming called-number .
this way you will force it to use RTP-NTE dtmf method for all alls, now since you do not have any dial-peers defined with it a default dial-peer 0 (H323) is matched which uses different DTMF method.
HTH, please rate all useful posts!
Chris
