09-01-2015 04:15 PM - edited 03-17-2019 04:10 AM
I have a Cisco CP-8861 phone ad I am wondering how to auto-provision it.
I am using a SIP setup so I must change the firmware to suit.
I know it has to be done through TFTP, The web UI is only used to display information as far as i can tell.
Is there any provisioning guide to show the steps how to do this, or even better if there were any generic config files that I can use as a template?
09-01-2015 07:19 PM
You should start by saying what you use for call control, and what version, you're using.
09-02-2015 11:20 AM
Asterix, and version of what?
09-02-2015 11:22 AM
Although few people use Asterix over here, however this is a Cisco forum and most of the people are only familiar with Cisco products, hence I believe it will be much easier if you posted this query on Asterix support platform.
09-03-2015 04:27 AM
Define "auto provision".
02-10-2017 07:12 AM
Hi, I have the exactly same the same issue, have you find any solution? Please let us know,Thanks
