Cisco 8831
michaelgitonga
What is the difference between Cisco 8831 Base/Control Panel (CP-8831-EU-K9=) and Cisco 8831 Daisy Chain Kit (CP-8831-DC-EU-K9=)?
2 Accepted Solutions
Rob Huffman
Hi Michael,
The 8831 Base/Control Panel is the "main" building block to configuring a Conference room setup as it has the Dial Pad & Display as well as the speaker and mic component. For room expansion you can add the 8831 Daisy Chain kit which gives you a second speaker/mic component without the Dial Pad & Display portion (which is then connected to the main piece via an 18 foot cable) .
The various configurations as well as power options are nicely explained in the doc linked below;
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-conference-phone-8831/guide-c07-734247.html
Cheers!
Rob
Brandon Buffin
Cisco 8831 Base/Control Panel includes one base and one control panel. Cisco 8831 Daisy Chain Kit includes one base and one daisy chain cable to allow you to use two base units with one control panel for a large room.
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/data_sheet_c78-726887.html
Brandon
5 Replies 5
Rob Huffman
Hi Michael,
Cheers!
Rob
Thank you.
Brandon Buffin
Brandon
Thank you.
Jaime Valencia
Have you looked at that in the data sheet?
java
if this helps, please rate
