Automatically adding a # when dialing a number using CME 4
herbst_lan
Hi all
I have 6xBRI lines.There is a delay when i dial out to the PSTN.The timeouts initial seeting is set to 5s
paolo bevilacqua
The delay is normal when you use T in destinatio-pattern. You can set "timeouts interdigit" to 3. Also, if you know that certain numbers are of fixed length (eg, all number starting with 45.....) are 8 digits,configure them in destination-pattern and for these there will no delay.
Hope this helps, please rate all useful posts!
