Avaya IP Office Integrating with Cisco CUCME
Sunish Nair
Please help me for integrating the CUCME with Avaya IP Office, if you can share your experiance it will be great. Because most of the documents related to UCM not for CUCME.
Thanks and Regards,
Sunish
Chris Deren
Here is integration guide for CME to Avaya S8500 via SIP:
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns829/785594.pdf
HTH,
Chris
Emmanuel Valdez
Level 3
Level 3
Hi Sunish,
What is your CUCME version?
This question is very important because the new CUCME versions need licences for SIP Trunk that is the best option to integrate the IP Office and the CUCME, you can use E1, FXS or FXO cards to integrate both platforms, what are you thinking to use?
Best regards.
Sunish Nair
Hi..Thanks for the Doc...
I am using version 7.1, do i require any license for this pourpse. As per my Understanding license is not required..
Is it possible to get the doc with H323...
Thanks and Regards,
Sunish
If you will use H323 you don´t need licenses, the document attached is very similar to the integration by H323, what are your enviroment settings? like IP Office extensions, IP address, CME IP address, extensions, etc.
Regards.
