Avaya phone and Cisco 4507R+E
sobrien
Need to know if I need to enable QOS on the swithcport that the phone is connected to or can I just use the MLS command?
5 Replies 5
Jaime Valencia
This is the Video Over IP forum, you might want to move this thread to some other community.
java
if this helps, please rate
Dennis Mink
It depends, if your Avaya phone uses DSCP settings for things like SIP signalling and RTP (af41 and or ef).
You can simply put a trust statement on your access port and pass it on.
Please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
Thanks for the reply. I only see the command qos trust extend cos 0-7? Not sure if this will help
sure does, If you set the access port to trust these IP presedence values, then you have to make absolutely sure that your phone sends the correct cos values.
please rate if helpful
Thanks. I will try and report back
