Avaya Phone integration with CCM
thakurveneet
I am running CCM version 4.2 in my netowork, I just want to know that can we integrate/use Avaya IP phones with CCM if yes then whats the procedure for that.
A quick response will be highly appreciated.
Thnks,
Veneet
bfollmer1
Depends... What make and model is your Avaya? Does your Avaya support QSIG? Do you have a Cisco (PSTN)router with one or more T1 interfaces available?
Does your Avaya have the capacity for a T1 card / CSU?
The make and model of Avaya phones are
4621 SWIP, I am not sure whether these models support QSIG and capacity for T1 card/CSU.
Yes We have one Cisco 3845 with T1 interfaces and we are using this as our Voice gateway.
All I want to know that what Changes do I need to do on CCM and Avaya phones in order to integrate both.
I'm sorry... I misread your orginal message. I do not know if you can use Avaya IP phones on a Cisco system. I'm sure if you got the Avaya phones to work, you would have a number of incompatiablities.
