B-ACD i cant hear from outside via SIP
Ahmed Zein
Dear All,
     i have CME router 2811 "Router 1"
CME           Version 7.0(0)
IOS              Version 12.4(15)XZ2
B-ACD configured under dial-peer 100 "H323 not SIP"
my connection to GW is via Dial-peer 8, SIP not H323
Topology as follow:
"GW"------SIPv2------"CME Router1"------IP Phone
1-from inside IP phone i can call 73432789651 "B-ACD number" and can hear the voice of welcome message.
          so there is no Audio files issue
2-from outside, i.e via SIP; call connect but i cant hear the voice of the message
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
h323
  h225 start-h245 on-connect
  h245 passthru all
sip
dial-peer voice 100 voip
service aa1
destination-pattern 73432789651
session target ipv4:192.168.1.1
incoming called-number 73432789651
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 8 voip
corlist outgoing call-longdistance
description Outgoing Long-distance Calls via INSYS
translation-profile outgoing INSYS
max-conn 8
destination-pattern 98[2-9].........
session protocol sipv2
session target ipv4:85.12.253.2
codec g711ulaw
fax-relay ecm disable
no fax-relay sg3-to-g3
fax rate 9600
fax protocol t38 ls-redundancy 3 hs-redundancy 2 fallback pass-through g711ulaw
no vad
Hints;
1- i tried to make dialpeer 100 use SIP and didnt work, i even cant hear from inside, also i cant hear from inside  if i changed the g711ulaw codec at Dial-peer 100.
2-sip to gateway is a must. i cant use H323 as my GW is a provider and i face many issues with h323
please try to help me as much as you can, it is very urgent issue and crucial.
2 Accepted Solutions
Hi Ahmed,
Could you please run all the debugs same time and collect in one file. If we have all the debug collect same time, i can see where excatly is issue.
Please log all of this to the router's buffer with these commands:
config t
no logging console
no logging monitor
no  logging rate-limit
no logging queue-limit
logging buffer 3000000 debug
After turning on the debugs, issue the command "clear log".  Then reproduce the issue.  After that, dump the contents of the log using: term len 0 show log
Vandana
Hi Ahmed,
I found one old bug, whcih should be fix by now, But still want to see if media is not playing because DTMF is not nego. To confirm you can try the workaround mentioned here. But for DTMf to work in any case, you would have to contact the provider to support it. You can also try the T train IOS.
CSCsj67507
CME BACD Does not work when comming in SIP
Symptom:
A sip call to a B-ACD script will not hear the Audio
Conditions:
If DTMF-RELAY is not configured on the inbound dial-peer
or if DTMF-RELAY is not negociated.
Workaround:
Both sides need to be configured with rtp-nte or sip-ntfy
If the Sip provider doesn't support DTMF-RELAY ,
you will have to loop the call to a h323 dial-peer
and define Service under the h323 dial-peer.
configuring DTMF-Relay is the best option unless drop through prompts
are configured
Further Problem Description:
Vandana
12 Replies 12
paolo bevilacqua
If you need guaranteed, time-bound support for business purposes, engage a reputable professional, Cisco certified partner, or the Cisco TAC - not a freely contributed user forum.
this device dont has a smartnet, any idea please?
vandana
Would you please collect the followin traces:
debug ccsip mess
debug h225 asn1
debug h245 asn1
debug voip ccapi inout
debug voi app scri
sh run
Vandana
Dear Vandan;
     all debugs requested are uploaded to my profile/documents
https://supportforums.cisco.com/people/Zeinovich?view=documents
hints:
B-ACD dial peer is 100, not the other dial peers, there is old dial peers in the configuration not used.
1- all these calls done from another city phone number 73462555512
2-i have created a SIP trunk to Provider gateway "dial peer 4321" just to separate the issue and change as much as i can
3-from internal phone i can call  73462555512
4-from internal i can hear the B-ACD welcoming and press digits to select the options
5-from outside "i.e 73462555512," i cant hear welcoming message , and cant press digits to select the options, i.e DTMF not working, not just voice of welcoming message of B-ACD
6-i cant see any H323 signaling or something, does the b-ACD dial-peer 100 use H323 or what??
Hi Ahmed,
config t
no logging console
no logging monitor
Vandana
Dear Vandan,
the file  Yekat_CME_debugs.log
  at my profile/docs
many thanks for your help, my friend
Hi Ahmed,
Can you have your provider send the rtp-nte or sip-notify for DTMF. I don't see either in invite.
Would you please try the following changes:
service aa1
sess pro sip
dtmf-relay rtp-nte sip-notify
codec g711ulaw
Dear Vandan,
A::FROM MY SIDE
1- i modefied the dial-peer 100 by adding
dtmf-relay rtp-nte
but i cant add sip-notify, as it is unrecognized command!!!
but the same issue, no voice, and dtfm not respond
2-how can i add sip-notify
B:FRM PROVIDER SIDE
1-i didnt ask them yet, but what exactly should i ask ?
C: you speak about DTMF , but why voice of welcom message not received??
D:why there is no H323  signaling in he debugs??
i am sorry for your time, but please i really need you help
waiting for your feedback dude.
Hi Ahmed,
CSCsj67507
Symptom:
Conditions:
Workaround:
are configured
Vandana
Vanda, I am really cant find words to thank you man
i will do your solution,
and it will resolved "In shaa ALLAH"
but please , can you clarify the 2nd solution, the workaround? how the loop dial-peer can be donem my frien?"
Hi Ahmed,
With this workaround, you would be able to hear media but DTMF still won't work, for that you need to contact your provider.
Vandana
Thanks a lot. It worked to my.
