IP Telephony and Phones
Labels
hello all, when i connect web page using ip phone 7965, the web page font have problem like this "[][]This[]is tes[]t web[]".how can i do for this problem? I don't know if it will help, but here's my configuration. ephone-template 3url-button 1 http:...
asdg by Level 1
  • 253 Views
  • 0 replies
Hi I'm new for cucm.Just got my be6k running and configure internal calls with users and phones. I can dial manually other phones but not through the coparate directory. The names are populated in the coparate directory but grayed out also it shows o...
zumriatha by Level 1
  • 324 Views
  • 1 replies
Hi there, Can someone please suggest what is the partnumber for the renewing the license "CUWL-PRO-K9", since this is EoL. Do i need to buy the replacement product itself, or do i have an option to upgrade/migrate. If so what is the partnumber Thanks...
sameeh.pp by Level 1
  • 317 Views
  • 2 replies
Hello All, I'm trying to register my Cisco cube router 3825 with the service provider. My cube is sending the register message with "expires: 0" even after receiving 200 OK. Are the below messages fine? As per the provider, the format is fine for th...
mailgunj by Level 1
  • 2604 Views
  • 11 replies
We have a hunt group for our product support. When everyone is on a call it goes to voicemail and although everything is setup correctly, they never get a voicemail. The voicemail picks up and it allows you to leave a voicemail but when they go to ch...
Hi Everyone, i want to ask about Route list registration:So my company has a h.323 gateway to avaya on one of branch office that has CUCM A sub  (let's say branch A). I've configured a route pattern, a route list, and a route group (which only have t...
We have a setup as follows:We have a Line Group for our Mortgage Loan Originators, and this is set up in a circular pattern in order to rotate calls. The numbers in the Line Group each forward to the MLOs' respective cell phones.We desire to have it ...
jmorton1 by Level 1
  • 427 Views
  • 1 replies
We have two (2) ISR 4321 connected to the ISP via SIP, we are getting disconnect and the only way to fix the issue is to restart the Interface.   We get the following issue.003116: *Aug 10 17:29:03.257: //34363/DFC86B29AAA7/SIP/Error/sipSPIFlushDefer...
