B-ACD not working
Anju Josua
Hi All,
need help related to b-acd, i am new about this.
if i call to pilot number, there no tone then call disconnected
already configure based on cisco doc:
application
service aa flash:bacd/app-b-acd-aa-3.0.0.7.tcl
paramspace english index 1
param number-of-hunt-grps 3
param menu-timeout 6
param handoff-string aa
param dial-by-extension-option 4
param moh bacd_music_on_hold.au
paramspace english language en
param max-time-vm-retry 2
param max-extension-length 3
param aa-pilot 500
paramspace english location flash:bacd
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param max-time-call-retry 600
param service-name callq
service callq flash:bacd/app-b-acd-3.0.0.7.tcl
param queue-len 10
param aa-hunt3 530
param aa-hunt1 510
param number-of-hunts-grps 3
param queue-manager-debugs 1
param aa-hunt2 520
dial-peer voice 1010 voip
service aa
destination-pattern 500
session target ipv4:10.10.70.2
incoming called-number 500
dtmf-relay rtp-nte
codec g711ulaw
no vad
debug from voice application error:
*Mar 20 09:30:48.164: //-1//TCLM:/tcl_hunt_group_num_calls_in_callq: B-ACD-SERVICE Tcl service not available
*Mar 20 09:30:48.936: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
*Mar 20 09:30:48.936: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
*Mar 20 09:30:48.936: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not found for tag(56)
*Mar 20 09:30:48.936: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
*Mar 20 09:30:48.937: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
*Mar 20 09:30:48.937: //387/AE442F60843B/SSIN:/AFW_SS_SIP_CheckConsultSetup: NULL setupSSApduList
*Mar 20 09:30:48.937: //387//Dest:/DestLocalConsultHandoff: no local handoff, intwrk leg 7F9C4ABE1CC0, consult id 7F9C4AF6D8E0
*Mar 20 09:30:48.941: //389//MEDI:/C_MediaFork_Close: Media Fork Not avtive on Leg [389]
*Mar 20 09:30:48.942: //387//MEDI:/C_MediaFork_Close:
Router_CME#Media Fork Not avtive on Leg [388]
*Mar 20 09:30:48.943: //387//MEDI:/C_MediaFork_Close: Media Fork Not avtive on Leg [387]
any sugestion?
regards,
Anju
yes, already solve the issue. what's your problem?
maybe you need to check the dial-peer and b-acd config.
thanks
anju
yasser.hero
if you have fixed this issue please help
i have the same
thanks
anju
Hi Anju,
On callq application you are missing a couple of params:
param maxHuntGroups 30
paramspace english prefix en
Than also remember to load all audio prompts by issuing the command audio-prompt load flash:filename.au
Please also post the output of a show call application session.
Carlo
Please rate all helpful posts "The more you help the more you learn"
