CUBE configurations to add another SIP
PriyaMK930726
Can any one let me know what is port channel in CUBE and what is the purpose of it? Why the port Channel binds to dial peers? What is SFP in cube? Why it is used for?
my cube is already configured with a SIP which is taking calls now. But the requirement is, we need to configure one more SIP from different provider in the cube.Can we configure two different SIP in one CUBE? If so could some one help me out to do the configurations? What are the things to do for new SIP configurations?
Total license in cube: 300
Kindly have a look on cube current configurations attached. (IP's are replaced)
Jaime Valencia
You can configure multi-tenants if you require multiple SIP providers.
java
if this helps, please rate
George Sotiropoulos
I think CUBE Multitenant configuration will be useful in your case:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-cube-multi-tenants.html
Hope this helps
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Can we configure 2 different sip in sip-ua? Is there any problem in it?
