Bandwith Utilization for Voice
Mubarak ali Ali
How can we check ,Voice Bandwith Utilization in Cisco Call Manager .is there is any tool for that
3 Accepted Solutions
Robert Thomas
Level 7
Level 7
You can use Locations to have CallManager track down the amount of Bandwidth used. Then you can use RTMT Perfomance counters to display the amount of bandwidth available on Real Time.
anchoudh
Level 9
Level 9
Hi Mubarak,
Please refer the below link,
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080094ae2.shtml
Also please refer "Table 5-3     Audio Codec Preference Order for Cisco Unified Communications Manager 8.5(1)"
in the below link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmsys/a02sycfg.html
Hope it helps.
Anand
Pls rate helpful posts !!
HI Mubarak,
To download RTMT from CUCM, please navigate to CUCM Admin->Applications->Plugins page->RTMT (for windows or Linux).
Hope it helps.
Anand
Pls rate helpful posts!!
5 Replies 5
Robert Thomas
Level 7
Level 7
Dear Robert ,
Can you provide me the link for donwloading RTMT ....
Thanks.,
HI Mubarak,
Hope it helps.
Anand
Thanks dear ,
I downloaded and i am able to monitor the calls .....
anchoudh
Level 9
Level 9
Hi Mubarak,
in the below link.
Hope it helps.
Anand
