01-24-2018 04:47 PM - edited 03-17-2019 12:02 PM
I'm using the Import/Export utility in BAT to change the partition on a large number of route patterns, but instead of just updating the existing route patterns, it's duplicating them. I understand there may not be a unique ID for route patterns, and because same route patterns in different partition are an acceptable configuration, the system does not complain. But is there a way to avoid adding the partition, and instead just udate the partition field only? Thanx!
01-24-2018 09:29 PM
01-25-2018 10:05 AM
Hi Mohammed,
I'm not a programmer, looked into AXL, seems great, but not something I can pickup in next day or so. Is there a guide that explains how to use it for my specific purpose that you can reference? Any guides or info on the matter would be greatly appreciated, thanx.
01-25-2018 10:11 PM
If AXL is not looking like an option for you, you could try SQL on the CLI of the Publisher.
In this example, we're updating all 600X patterns in the Old-PT partition, to be in the New-PT partition.
run sql update numplan set fkroutepartition = (select pkid from routepartition where name = 'New-PT') where fkroutepartition = (select pkid from routepartition where name = 'Old-PT') and dnorpattern matches '600[0-9]'
02-28-2023 06:02 AM
Hi I have a list of Routte Patterns that i,d like to update his partitions to a new partition.
Example: Change all of this from Old Partition to a New Partition.
00[^0][^0].912121XXXX
00[^0][^0].912122XXXX
00[^0][^0].912123XXXX
00[^0][^0].912125XXXX
00[^0][^0].912126XXXX
How can we manage this?
Fernando Penteado
