BAT - Update Lines Via CSV File
m.gravel
Is there anyway to do this? The only way I can find so far is by a query as per below but I require the ability to specify specific DN's in a CSV file.
In CUCM under Bulk Administration --> Phones --> Add/Update Lines --> Update Lines
You can then search by:
  • Directory Number
  • Route Partition
  • Line Description
  • CSS (Phone)
  • CSS (Line)
  • Device Pool
  • Device Description
  • Line Position
  • Unassigned DN
  • Call Pickup Group
Rob Huffman
Hi there,
I believe you would use the method detailed by one of my faves, Bill Bell, in this
great thread
https://supportforums.cisco.com/message/3039692#3039692
Cheers!
Rob
"Everything is broken" - Bob Dylan
