BE6000 Maximum Registered Phones
I have a environment (BE6k-M supports 1200 devices). Actually I have 1000+ registered phones.
I would like to know what will happen if I try to register the 1201th device? My cluster will reject that registration?
[ ]'s
Jaime Valencia
No, it will not tell you anything, won't prevent you from registering them, etc. (assuming enough licenses are provided)
BUT doing so, means you'll be losing all Cisco support as you're going beyond the tested number of devices to guarantee performance on that platform.
java
if this helps, please rate
Jaime Valencia
java
Tagir Temirgaliyev
what is cucm version? 8 ? 9 ?
