BE7000M with VMware ESXi 5.5: SNMP MIB to get CPU Performance Counters
raziel78kain
Level 2
Level 2
we have some BE7000M servers with VMware ESXi 5.5, and we would like to know if there is an SNMP MIB that permits to get the CPU Performance Counters (i.e, the Latest, Maximum, Minimum, and Average usage values, for every CPU).
If not, is there a way to get these values remotely, but without using the VMware vSphere Client?
TIA and regards.
If you want to monitor the CPU usage from CUCM using SNMP, below are the OIDs and useful links.
OID for CPU 1.3.6.1.2.1.25.3.3.1.2
OID for memory 1.3.6.1.2.1.25.2.3.1.6
http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.2.1.25.3.3.1.2&translate=Translate&submitValue=SUBMIT
If you want to monitor the VM CPU and Host CPU from ESXi SNMPm below are the OIDs and useful links
OID for CPU Table by Virtual Machine 1.3.6.1.4.1.6876.3.1.2
OID for Hardware Processor Table 1.3.6.1.2.1.25.3.3
http://www.circitor.fr/Mibs/Html/VMWARE-RESOURCES-MIB.php
http://selaschuk.blogspot.ae/2013/11/monitoring-esxi-cpumemory-via-snmp.html
