Because when the Cisco model 7945 speaker phone is picked up, a number is automatically dialed
Rosch.
Hi Community,
I hope you're well
My issue is when I pick up the handset of the phone is automatically marked a number, it can be the directory or any other number that does not exist. The user does not configure anything on the device or any speed dial. I already have four cases in the week that happens.
What I do to solve, is to disconnect the voip phone from the network and reconnect.
Is it possible for the user to dial by mistake for this to happen?
Thanks for your help!
Jaime Valencia
You need to mention everything that is involved to get assistance.
CUCM?? CME?? version??
Do you have PLAR configured?
java
if this helps, please rate
CUCM - version: 11.5.1.15900-18.
I do not have PLAR configured.
OK, are they SCCP or SIP phones?
If it's a random number they dial, and the phone is sending those digits, you can see that in the CUCM traces.
java
Hi!
Only SCCP. I will review the traces in the CUCM.
Or could it be some hardware error?
