Beep sound during voice call. CUCM
Sonam
I have CUCM 11.x and ip phone 7821 model. I have UCCX integrated with cucm and few contact center agents using ip phone to receive call. When receiving call from PSTN, there is beep sound when getting connecting to agent and this beep sound repeats after certain secs. This sound is very irritating to both customer and agent. Please help me how to get rid of this beep sound when on call.
5 Replies 5
Hari Prasad
Hello Sonam,
First of all, you call internally from IP phone to CTI RP of the UCCX number (Mail line number) to verify that no issue with between CUCM and UCCX
Dial the CTI RP which is pointed towards UCCX Trigger >>Application>>Script
If you observe Beep sound in above test scenario then you need to take packet capture from each hop.
If you don't face issue in above scenario then I will suggest to take PCM capture of ISDN leg and open TAC case to decode. TAC will give clarity on beep sound.
Please rate helpful posts
Thanks, Hari Prasad
Hello Prasad,
I dialed Trigger number(CTI RP) internally from ip phone and the beep sound is there. Please advise how to take packet capture and from which all hops.
Thank you
jason-mcgee
Level 3
Level 3
Sonam,
Is the person assigned to that phone an agent? If so, do you have the recording tones set to on in CUCM? Do you have other phones or agents that are being recorded with the tone active? Since it repeats at interval, it seems as if it is a recording tone which can also be generated by the calling party as well.
Jason
Hi Jason,
Yes,
NO, the recording tones is disabled on cucm on each phone.
No, i have disabled recording tone for all agents/phone.
How do i check on this? I have agents in different team and location, with no such issue. No beep sound for them. But for other team , beep sound is there. Please help!
