BIB
Anand Sharma
Can anyone let me know the models number among Cisco IP Phone 7800 and 8800 thats support BIB(Built In bridge) feature?
Jaime Valencia
You can get that from your server
http://docwiki.cisco.com/wiki/Endpoints_FAQ#How_to_tell_if_a_phone_.2F_endpoint_is_compatible_with_a_certain_CUCM_feature.3F.3F
java
if this helps, please rate
Thats means each of these series IP Phone have this feature its depends on server?
+5 Jaime.
Anand, feature support depends on the combination of cucm, phone hardware and its firmware.
CUCM reporting capability can tell you whether its supported or not from CUCM perspective combined with phone hardware. But you need to make sure that correct firmware is running on the phone. The phone can download the firmware from CUCM during registration process.
Hi Anand,
Please do find the list of phones which have Built in Bridge Feature enabled
Phones with Built in Bridge Feature
Anoop
