07-18-2008 11:18 AM - edited 03-15-2019 12:03 PM
Recently I have added 7914 expansion module for one user. As per the request I defined the some extensions and BLF-SD button on module. Issue is the BLF - busy lamp is not working, only speed dial is working .Has anyone ever experienced this issue before?
Thanks in advance.
07-18-2008 11:42 AM
Does it work on one of the buttons on the phone?
Do you have subscribe CSS defined on the phone with access to the parition of monitored phone?
Chris
07-18-2008 11:47 AM
Hi friend,
I have experienced this issue in the past. If this is CallManager, please check in the ephone configuration page (under Protocol Specific Information) if you have assigned a CSS in "SUBSCRIBE Calling Search Space" field. If not, assign a calling search space that contains the partition that contains the DN that you're monitoring.
Hope this helps a little bit.
- Adrián.
02-22-2016 07:18 AM
This helped me today thank you!
D
