BLF SD red light is always on[cisco 8851]
iptsupport
Level 4
Level 4
Hello ,
I have issue with cisco 8851.
The BLF-SD light is always on phone.
if I  made factor reset the problem fix .
my version sip 88xx-10-2-2-16
any idea ?
5 Replies 5
Manish Gogna
Is it affecting all 8851's or just one of them?
Does the issue return automatically after factory reset as well or factory reset fixes it completely?
Manish
1.all phones.
2.The issue return automatically after factory reset(Time is undefined).
I would suggest an upgrade to latest firmware 11.5.1 to see if that resolves the issue
https://software.cisco.com/download/release.html?mdfid=286255328&flowid=54175&softwareid=282074288&release=11.5(1)&relind=AVAILABLE&rellifecycle=&reltype=latest
One of the bugs that i suspect is the following that applies to 88XX phones
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuu62252/?reffering_site=dumpcr
Manish
I have same problem
we check again with customer and one of cisco 8851 have a problem.
any idea?
